跳转到主内容
Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement
你所需要的
  1. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: 步骤 1 中的图像 1,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: 步骤 1 中的图像 2,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: 步骤 1 中的图像 3,3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 2 中的图像 1,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 2 中的图像 2,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 2 中的图像 3,3
    • Use a T8 screwdriver to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 3 中的图像 1,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 3 中的图像 2,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 3 中的图像 3,3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 4 中的图像 1,1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 5 中的图像 1,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 5 中的图像 2,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 5 中的图像 3,3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 6 中的图像 1,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 6 中的图像 2,3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 6 中的图像 3,3
    • Remove the ribbon cable from the slot on the speaker board
  7. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker board which contains the analog to digital converter
结论
团队
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G3
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 2,709
