跳转到主内容
Amazon Echo 2nd Generation MLB Board Replacement
你所需要的
  1. Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: 步骤 1 中的图像 1,3 Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: 步骤 1 中的图像 2,3 Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: 步骤 1 中的图像 3,3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation MLB Board Replacement: 步骤 2 中的图像 1,3 Amazon Echo 2nd Generation MLB Board Replacement: 步骤 2 中的图像 2,3 Amazon Echo 2nd Generation MLB Board Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation MLB Board Replacement: 步骤 3 中的图像 1,2 Amazon Echo 2nd Generation MLB Board Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  4. Amazon Echo 2nd Generation MLB Board Replacement, Subwoofer (speaker): 步骤 4 中的图像 1,2 Amazon Echo 2nd Generation MLB Board Replacement, Subwoofer (speaker): 步骤 4 中的图像 2,2
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
  5. Amazon Echo 2nd Generation MLB Board Replacement: 步骤 5 中的图像 1,2 Amazon Echo 2nd Generation MLB Board Replacement: 步骤 5 中的图像 2,2
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
  6. Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: 步骤 6 中的图像 1,3 Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: 步骤 6 中的图像 2,3 Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: 步骤 6 中的图像 3,3
    • Lift the MIC board over and lay it down against a surface.
    • Disconnect the ribbon cable from the MIC board and pull the board away.
  7. Amazon Echo 2nd Generation MLB Board Replacement, Front Cover Panel: 步骤 7 中的图像 1,2 Amazon Echo 2nd Generation MLB Board Replacement, Front Cover Panel: 步骤 7 中的图像 2,2
    • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
    • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Flip the device over while supporting the front panel side.
    • Remove the front panel cover by lifting it.
  8. Amazon Echo 2nd Generation MLB Board Replacement, MLB Board: 步骤 8 中的图像 1,2 Amazon Echo 2nd Generation MLB Board Replacement, MLB Board: 步骤 8 中的图像 2,2
    • Remove the white plastic shielding and the black silicon cover.
    • Remove the metal cover beneath the black silicon cover.
  9. Amazon Echo 2nd Generation MLB Board Replacement: 步骤 9 中的图像 1,1
    • Carefully lift up the MLB board. Underneath it is another ZIF connector. Use a spudger to flip the small flap on the ZIF connector.
    • This will take a few tries to get it done correctly. Remember to not use too much force as you do not want to damage the ZIF connector.
    • Remove the MLB Board by flipping the device over and letting it fall into your hands.
    • Completely remove the ribbon cable from the case, reattach it to the MLB board, then place the board and ribbon cable back into its original position.
结论
另外一个人完成了本指南。
Billy Pho
于10/08/18注册
491 声望
创作了2篇指南
团队
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 的会员
CPSU-WHITE-F18S4G4
3 名成员
创作了5篇指南
3指南评论
Hi,
where can i can the MLB board?
Pierre Troussard - 回复
Have you managed to source one yet?
Neil -
Yes, where does on get the MLB board?
Neil - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 109
总计 4,284
