简介
Follow this guide if any of the four buttons on the front panel do not work or are broken.
配件
无需配件。
  1. Remove the rubber layer beneath the device. Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand. Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Use a spudger to flip up the small flap on the ZIF connector. Gently pull the ribbon cable out of the ZIF connector. Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Use a spudger to lift up one of the small flaps on only one side of the female connector. Pull on the wire toward the lifted side until the male connector is disconnected.
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  5. Remove the four 30.0 mm T8 Torx screws in the corners. Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
  6. Remove the lid on top of the subwoofer. Flip the device over and let the subwoofer fall into your hand.
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
  7. Remove the four 16.0 mm T8 Torx screws underneath the speaker. Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
    • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Flip the device over while supporting the front panel side.
    • Remove the front panel cover by lifting it.
结论
Eric Inman
于2018年10月08日注册
283 信誉积分
创作了3篇指南
团队
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 的会员
CPSU-WHITE-F18S4G4
3 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 2
过去的7天: 6
过去的30天: 25
总计 114
