跳转到主内容
Amazon Echo 2nd Generation AMP Board Replacement
你所需要的
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 步骤 1 中的图像 1,3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 步骤 1 中的图像 2,3 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 步骤 1 中的图像 3,3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation AMP Board Replacement: 步骤 2 中的图像 1,3 Amazon Echo 2nd Generation AMP Board Replacement: 步骤 2 中的图像 2,3 Amazon Echo 2nd Generation AMP Board Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation AMP Board Replacement: 步骤 3 中的图像 1,2 Amazon Echo 2nd Generation AMP Board Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
结论
另外一个人完成了本指南。
Eric Inman
于10/08/18注册
301 声望
创作了3篇指南
团队
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 的会员
CPSU-WHITE-F18S4G4
3 名成员
创作了5篇指南
3条评论
Can anyone find a replacement board?
Tristan Parks - 回复
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - 回复
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 48
总计 3,546
