跳转到主内容
Amana NGD4655EW1 Dryer Door Handle Replacement
你所需要的
  1. Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: 步骤 1 中的图像 1,2 Amana NGD4655EW1 Dryer Door Handle Replacement, Door Handle: 步骤 1 中的图像 2,2
    • Clean the area around the door handle with a cloth.
  2. Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 2 中的图像 1,1
    • Position the door handle replacement where it suits you best.
    • Use a level to make sure the door handle is straight and neat.
  3. Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 3 中的图像 1,2 Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 3 中的图像 2,2
    • Use a marker to mark where the four screws are going to be placed.
  4. Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 4 中的图像 1,2 Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 4 中的图像 2,2
    • Place the point of a center punch in the middle of a mark.
    • Take a rubber mallet and lightly hit the top of the center punch to make an indentation in the dryer door.
    • Repeat this process for the other three marks.
  5. Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 5 中的图像 1,2 Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 5 中的图像 2,2
    • Use a 1/4" nut driver to drive the Tek screws into the four indentations.
    • Be sure to sweep up and dispose of any metal shavings before moving on.
  6. Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 6 中的图像 1,3 Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 6 中的图像 2,3 Amana NGD4655EW1 Dryer Door Handle Replacement: 步骤 6 中的图像 3,3
    • Line up the holes in your new handle with the holes in the dryer door.
    • Screw the Tek screws in the holes previously made, securing the handle into the dryer door.
结论
You should now have a fully functional door handle for your Amana dryer machine!
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 673
