跳转到主内容
Aluratek ADMPF310F Screen Replacement
你所需要的
  1. Aluratek ADMPF310F Screen Replacement, Screen: 步骤 1 中的图像 1,3 Aluratek ADMPF310F Screen Replacement, Screen: 步骤 1 中的图像 2,3 Aluratek ADMPF310F Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Screen Replacement: 步骤 2 中的图像 1,1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Screen Replacement: 步骤 3 中的图像 1,2 Aluratek ADMPF310F Screen Replacement: 步骤 3 中的图像 2,2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Screen Replacement: 步骤 4 中的图像 1,1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
结论
Chris Belair
于10/20/16注册
333 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 587
