跳转到主内容
Aluratek ADMPF310F Motherboard Replacement
你所需要的
  1. Aluratek ADMPF310F Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Aluratek ADMPF310F Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Motherboard Replacement: 步骤 3 中的图像 1,2 Aluratek ADMPF310F Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Motherboard Replacement: 步骤 6 中的图像 1,2 Aluratek ADMPF310F Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Motherboard Replacement: 步骤 7 中的图像 1,3 Aluratek ADMPF310F Motherboard Replacement: 步骤 7 中的图像 2,3 Aluratek ADMPF310F Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
结论
Pascal Alexis
于11/05/15注册
427 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-1, Martin Fall 2016 UMass Dartmouth, Team 5-1, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 558
