跳转到主内容
Altec Lansing VersA Smart External Panel Removal
你所需要的
  1. Altec Lansing VersA Smart External Panel Removal, External Panels: 步骤 1 中的图像 1,1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart External Panel Removal: 步骤 2 中的图像 1,2 Altec Lansing VersA Smart External Panel Removal: 步骤 2 中的图像 2,2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart External Panel Removal: 步骤 3 中的图像 1,2 Altec Lansing VersA Smart External Panel Removal: 步骤 3 中的图像 2,2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart External Panel Removal: 步骤 4 中的图像 1,1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 148
