跳转到主内容
Altec Lansing Mini Lifejacket 2 Speaker Replacement
你所需要的
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 2 中的图像 1,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 2 中的图像 2,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 2 中的图像 3,3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 3 中的图像 1,2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 4 中的图像 1,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 4 中的图像 2,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 5 中的图像 1,2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 5 中的图像 2,2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 6 中的图像 1,2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 6 中的图像 2,2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 8 中的图像 1,1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 9 中的图像 1,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 9 中的图像 2,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 9 中的图像 3,3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: 步骤 10 中的图像 1,2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: 步骤 10 中的图像 2,2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 11 中的图像 1,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 11 中的图像 2,3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 11 中的图像 3,3
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 12 中的图像 1,2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: 步骤 12 中的图像 2,2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
结论
另外一个人完成了本指南。
Stephen Albrecht
于02/14/18注册
1,029 声望
创作了4篇指南
团队
USF Tampa, Team S3-G2, Nance Spring 2018 USF Tampa, Team S3-G2, Nance Spring 2018 的会员
USFT-NANCE-S18S3G2
4 名成员
创作了4篇指南
2条评论
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - 回复
Where can I get this speaker parts?
T Rex movies - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 4,026
