跳转到主内容
Altec Lansing BoomJacket Bluetooth Board Replacement
你所需要的
  1. Altec Lansing BoomJacket Bluetooth Board Replacement, Case Removal: 步骤 1 中的图像 1,1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 2 中的图像 1,1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 3 中的图像 1,1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 4 中的图像 1,1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 5 中的图像 1,2 Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 5 中的图像 2,2
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 6 中的图像 1,1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 7 中的图像 1,1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Bluetooth Board Replacement, Bluetooth Board: 步骤 8 中的图像 1,1
    • Now that the case is open look for the small green (NFC) chip on the inside of the case next to the motherboard.
  9. Altec Lansing BoomJacket Bluetooth Board Replacement: 步骤 9 中的图像 1,1
    • Disconnect the Bluetooth (NFC) chip from the motherboard.
结论
2等其他人完成本指南。
一条评论
Is this a common issue with the Lifejacket 3? I was able to use my new BT speaker twice, since it was bought last week. The speaker hasn't been dropped, in or around water, outside, left on, damaged, or tampered with.
Kat - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 4,708
