跳转到主内容
Altec Lansing BoomJacket Battery Replacement
你所需要的
  1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: 步骤 1 中的图像 1,1
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Battery  Replacement: 步骤 2 中的图像 1,1
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Battery  Replacement: 步骤 3 中的图像 1,1
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Battery  Replacement: 步骤 4 中的图像 1,1
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Battery  Replacement: 步骤 5 中的图像 1,2 Altec Lansing BoomJacket Battery  Replacement: 步骤 5 中的图像 2,2
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Battery  Replacement: 步骤 6 中的图像 1,1
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Battery  Replacement: 步骤 7 中的图像 1,1
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Battery  Replacement, Battery: 步骤 8 中的图像 1,1
    • The battery will be sitting right behind the speakers when the case is open.
  9. Altec Lansing BoomJacket Battery  Replacement: 步骤 9 中的图像 1,1
    • Unplug and disconnect the battery from the motherboard.
结论
5等其他人完成本指南。
6条评论
Where can you buy a replacement battery?
Darrell riley - 回复
Where can you buy the battery please?
Juan Roa - 回复
Where can I find ghe batteries? What type of battery ?
Violet Roach - 回复
where ca i buy a replacement battery
Shelley Franck - 回复
This tutorial is incomplete.
Ivan Rodriguez - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 49
总计 14,529
