跳转到主内容
Altec Lansing BoomJacket 2 Speaker Replacement
你所需要的
  1. Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: 步骤 1 中的图像 1,2 Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: 步骤 1 中的图像 2,2
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 2 中的图像 1,2 Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 2 中的图像 2,2
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 3 中的图像 1,1
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 4 中的图像 1,2 Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Unscrew the four screws holding the speaker in place.
  8. Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 8 中的图像 1,2 Altec Lansing BoomJacket 2 Speaker Replacement: 步骤 8 中的图像 2,2
    • Unscrew the two screws on the smaller speaker.
    • Pull the small speaker through the larger speaker hole.
结论
另外一个人完成了本指南。
Zach Braaten
于07/12/18注册
537 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 483
