跳转到主内容
AlphaSmart Pro Motherboard Replacement
你所需要的
  1. AlphaSmart Pro Motherboard Replacement, Separating Panels: 步骤 1 中的图像 1,3 AlphaSmart Pro Motherboard Replacement, Separating Panels: 步骤 1 中的图像 2,3 AlphaSmart Pro Motherboard Replacement, Separating Panels: 步骤 1 中的图像 3,3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 1,3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 2,3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: 步骤 2 中的图像 3,3
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • Remove front panel from the motherboard.
  3. AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 1,3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 2,3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: 步骤 3 中的图像 3,3
    • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
    • Gently lift the keyboard from the rear panel.
    • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
  4. AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 1,3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 2,3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: 步骤 4 中的图像 3,3
    • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
    • Pull the ribbon cable to remove it from the connector.
    • Repeat the exact steps above for the other ribbon cable.
    • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
  5. AlphaSmart Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove keyboard from motherboard.
  6. AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 步骤 6 中的图像 1,2 AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: 步骤 6 中的图像 2,2
    • Flip the AlphaSmart Pro over so that the rear panel is facing upward.
    • Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
  7. AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 步骤 7 中的图像 1,2 AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: 步骤 7 中的图像 2,2
    • Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
    • Carefully lift the motherboard away from the rear panel.
结论
Ashley Orr
于10/13/14注册
130 声望
创作了2篇指南
团队
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G1
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 647
