跳转到主内容
加入维修社区 - 创建账户
Alldaymall A88X LCD Screen and Touch Sensor Assembly Replacement
你所需要的
  1. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: 步骤 3 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: 步骤 3 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Speaker: 步骤 3 中的图像 3,3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 4 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 4 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 5 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 5 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 5 中的图像 3,3
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: 步骤 6 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: 步骤 6 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Camera: 步骤 6 中的图像 3,3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 7 中的图像 1,2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 7 中的图像 2,2
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 8 中的图像 1,2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 9 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 9 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 9 中的图像 3,3
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 10 中的图像 1,1
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 11 中的图像 1,1
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 12 中的图像 1,2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 12 中的图像 2,2
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
  13. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: 步骤 13 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: 步骤 13 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, Motherboard: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
    • Using a pair of tweezers remove the ribbon cable from its receptacle.
  14. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 14 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 14 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 14 中的图像 3,3
    • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
  15. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 15 中的图像 1,2 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 15 中的图像 2,2
    • Desolder the wires that connect the backlight to the motherboard.
  16. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 16 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 16 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 16 中的图像 3,3
    • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
  17. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement: 步骤 17 中的图像 1,1
    • Carefully lift up on the motherboard from its housing.
  18. Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: 步骤 18 中的图像 1,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: 步骤 18 中的图像 2,3 Alldaymall A88X LCD Screen and Touch Sensor Assembly  Replacement, LCD Screen and Touch Sensor Assembly: 步骤 18 中的图像 3,3
    • Gently pry the brackets holding the touch sensor to the LCD Screen
    • Do not bend the touch sensor to much as it may shatter.
结论
另外一个人完成了本指南。
Drhaber
于02/10/16注册
985 声望
创作了7篇指南
团队
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 的会员
USFT-LACY-S16S4G1
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 748
