简介
Prerequisites
- Follow the procedure in Before working inside your computer
CAUTION: Solid-state drives are fragile. Exercise care when handling the solid-state drive.
CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
This computer supports two solid-state drive form factors in SSD slot one:
● M.2 2230
● M.2 2280
你所需要的
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and the system board.
Lift the thermal shield off the solid-state drive.
Slide and lift the solid-state drive off the solid-state drive slot on the system board.
Slide to remove the screw mount from the palm-rest and keyboard assembly.
Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
另外一个人完成了本指南。
