跳转到主内容
Alienware X51 Motherboard Replacement
你所需要的
  1. Alienware X51 Motherboard Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Motherboard Replacement, Fan: 步骤 3 中的图像 1,2 Alienware X51 Motherboard Replacement, Fan: 步骤 3 中的图像 2,2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Motherboard Replacement: 步骤 5 中的图像 1,3 Alienware X51 Motherboard Replacement: 步骤 5 中的图像 2,3 Alienware X51 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Motherboard Replacement, Disc Drive: 步骤 6 中的图像 1,2 Alienware X51 Motherboard Replacement, Disc Drive: 步骤 6 中的图像 2,2
    • Disconnect the optical-drive data and power cable.
  7. Alienware X51 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
  8. Alienware X51 Motherboard Replacement, RAM: 步骤 8 中的图像 1,3 Alienware X51 Motherboard Replacement, RAM: 步骤 8 中的图像 2,3 Alienware X51 Motherboard Replacement, RAM: 步骤 8 中的图像 3,3
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
  9. Alienware X51 Motherboard Replacement, Heatsink: 步骤 9 中的图像 1,3 Alienware X51 Motherboard Replacement, Heatsink: 步骤 9 中的图像 2,3 Alienware X51 Motherboard Replacement, Heatsink: 步骤 9 中的图像 3,3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
  10. Alienware X51 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,2 Alienware X51 Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,2
    • Remove the single 1.0 mm screw with a Phillips #1 screwdriver.
    • Firmly remove the internal PC system by lifting it out of the PC.
  11. Alienware X51 Motherboard Replacement: 步骤 11 中的图像 1,2 Alienware X51 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Loosen the four 1.0 mm screws holding down the motherboard using a Phillips #1 screwdriver.
  12. Alienware X51 Motherboard Replacement: 步骤 12 中的图像 1,2 Alienware X51 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the two SATA plugs going into the motherboard processor.
  13. Alienware X51 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Disconnect the rectangular power supply plug from the motherboard into the other circuit board.
  14. Alienware X51 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Disconnect the bundled cable connector going into the motherboard.
  15. Alienware X51 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Disconnect the white bundled cable connector from the motherboard.
  16. Alienware X51 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Disconnect the rectangular yellow bundled cable connector plug going into the motherboard.
  17. Alienware X51 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Disconnect the power supply.
  18. Alienware X51 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Disconnect the rectangular white bundled cable connector going into the motherboard.
  19. Alienware X51 Motherboard Replacement: 步骤 19 中的图像 1,2 Alienware X51 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Gently slide and lift out the motherboard from the PC.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 382
