跳转到主内容
Alienware P18G M14X R1 Optical Drive Replacement
你所需要的
  1. Alienware P18G M14X R1 Optical Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Optical Drive Replacement, Battery: 步骤 4 中的图像 1,1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 5 中的图像 1,2 Alienware P18G M14X R1 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 1,1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Optical Drive Replacement: 步骤 9 中的图像 1,1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
结论
Andonaq Grozdani
于03/01/18注册
892 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 455
