跳转到主内容
Alienware P18G M14X R1 Hard Drive Replacement
你所需要的
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: 步骤 4 中的图像 1,1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 5 中的图像 1,2 Alienware P18G M14X R1 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: 步骤 7 中的图像 1,1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: 步骤 10 中的图像 1,1
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Pull the clip away from the hard drive to remove it.
结论
6等其他人完成本指南。
Andonaq Grozdani
于03/01/18注册
892 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 2,857
