跳转到主内容
Alienware M18x Internal Fan Replacement
你所需要的
  1. Alienware M18x Internal Fan Replacement, Internal Fan: 步骤 1 中的图像 1,3 Alienware M18x Internal Fan Replacement, Internal Fan: 步骤 1 中的图像 2,3 Alienware M18x Internal Fan Replacement, Internal Fan: 步骤 1 中的图像 3,3
    • Turn the computer over.
    • Slide the battery latch over and lift the battery out.
  2. Alienware M18x Internal Fan Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four indicated screws with a J000 screwdriver.
  3. Alienware M18x Internal Fan Replacement: 步骤 3 中的图像 1,2 Alienware M18x Internal Fan Replacement: 步骤 3 中的图像 2,2
    • Use the plastic pryer tool to lift the bottom cover off.
  4. Alienware M18x Internal Fan Replacement: 步骤 4 中的图像 1,2 Alienware M18x Internal Fan Replacement: 步骤 4 中的图像 2,2
    • With the back cover removed, locate the desired fan to replace.
  5. Alienware M18x Internal Fan Replacement: 步骤 5 中的图像 1,3 Alienware M18x Internal Fan Replacement: 步骤 5 中的图像 2,3 Alienware M18x Internal Fan Replacement: 步骤 5 中的图像 3,3
    • Use a J000 screwdriver to loosen the screws that secure the fan(s).
    • There are three internal fans within the laptop. Locate the correct screws to loosen for the desired fan to replace based on the provided corresponding images.
  6. Alienware M18x Internal Fan Replacement: 步骤 6 中的图像 1,3 Alienware M18x Internal Fan Replacement: 步骤 6 中的图像 2,3 Alienware M18x Internal Fan Replacement: 步骤 6 中的图像 3,3
    • The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
  7. Alienware M18x Internal Fan Replacement: 步骤 7 中的图像 1,2 Alienware M18x Internal Fan Replacement: 步骤 7 中的图像 2,2
    • The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
结论
Jonathan Panella
于02/21/18注册
470 声望
创作了2篇指南
团队
Cal Poly, Team S21-G1, Banghart Winter 2018 Cal Poly, Team S21-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S21G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 535
