跳转到主内容
Alienware M17x P01E Coin Cell Battery Replacement
你所需要的
  1. Alienware M17x P01E Coin Cell Battery  Replacement, Battery: 步骤 1 中的图像 1,1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Coin Cell Battery  Replacement: 步骤 2 中的图像 1,2 Alienware M17x P01E Coin Cell Battery  Replacement: 步骤 2 中的图像 2,2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Coin Cell Battery  Replacement, Compartment Door: 步骤 3 中的图像 1,1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Coin Cell Battery  Replacement: 步骤 4 中的图像 1,2 Alienware M17x P01E Coin Cell Battery  Replacement: 步骤 4 中的图像 2,2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Coin Cell Battery  Replacement, Coin Cell Battery: 步骤 5 中的图像 1,1
    • Gently pull on the coin cell battery cable to disconnect it from the laptop.
  6. Alienware M17x P01E Coin Cell Battery  Replacement: 步骤 6 中的图像 1,1
    • Pull on the battery to remove.
结论
Jose
于09/19/18注册
324 声望
创作了3篇指南
团队
CSU Fullerton, Team S2-G2, Bruce Fall 2018 CSU Fullerton, Team S2-G2, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 518
