跳转到主内容
Alienware M17x P01E Center Control Cover Replacement
你所需要的
  1. Alienware M17x P01E Center Control Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Center Control Cover Replacement: 步骤 2 中的图像 1,2 Alienware M17x P01E Center Control Cover Replacement: 步骤 2 中的图像 2,2
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Center Control Cover Replacement, Compartment Door: 步骤 3 中的图像 1,1
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Center Control Cover Replacement: 步骤 4 中的图像 1,2 Alienware M17x P01E Center Control Cover Replacement: 步骤 4 中的图像 2,2
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 步骤 5 中的图像 1,3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 步骤 5 中的图像 2,3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: 步骤 5 中的图像 3,3
    • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
  6. Alienware M17x P01E Center Control Cover Replacement: 步骤 6 中的图像 1,2 Alienware M17x P01E Center Control Cover Replacement: 步骤 6 中的图像 2,2
    • Turn the laptop top side up and fully open the display.
    • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
    • Pry the center control panel up from its left and right edges with the Spudger.
    • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
  7. Alienware M17x P01E Center Control Cover Replacement: 步骤 7 中的图像 1,2 Alienware M17x P01E Center Control Cover Replacement: 步骤 7 中的图像 2,2
    • Lift the center control panel from the laptop.
    • Tilt the center control panel away from the display carefully.
    • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
结论
Grant Dolmat
于09/17/18注册
328 声望
创作了2篇指南
团队
CSU Fullerton, Team S2-G2, Bruce Fall 2018 CSU Fullerton, Team S2-G2, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 440
