跳转到主内容
Alienware M17x Display Assembly Replacement
你所需要的
  1. Alienware M17x Display Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Alienware M17x Display Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Display Assembly Replacement: 步骤 4 中的图像 1,2 Alienware M17x Display Assembly Replacement: 步骤 4 中的图像 2,2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,1
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
  6. Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 1,3 Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 2,3 Alienware M17x Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
  7. Alienware M17x Display Assembly Replacement: 步骤 7 中的图像 1,2 Alienware M17x Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to disconnect the screen from the top mount.
  8. Alienware M17x Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
  9. Alienware M17x Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 792
