跳转到主内容
简介
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  4. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
结论
6等其他人完成本指南。
Gabe
于2010年04月09日注册
8,122 信誉积分
创作了3篇指南
团队
Master Techs Master Techs 的会员
Community
287 名成员
创作了819篇指南
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 8
总计 23,993
