跳转到主内容
Alienware M15x RAM Replacement
你所需要的
  1. Alienware M15x RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x RAM Replacement: 步骤 2 中的图像 1,3 Alienware M15x RAM Replacement: 步骤 2 中的图像 2,3 Alienware M15x RAM Replacement: 步骤 2 中的图像 3,3
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x RAM Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two screws indicated
  4. Alienware M15x RAM Replacement: 步骤 4 中的图像 1,2 Alienware M15x RAM Replacement: 步骤 4 中的图像 2,2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
结论
7等其他人完成本指南。
Gabe
于04/09/10注册
8,013 声望
创作了3篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
一条评论
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24,232
