跳转到主内容
Alienware M15x Hard Drive Replacement
你所需要的
  1. Alienware M15x Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x Hard Drive Replacement: 步骤 2 中的图像 1,3 Alienware M15x Hard Drive Replacement: 步骤 2 中的图像 2,3 Alienware M15x Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x Hard Drive Replacement: 步骤 3 中的图像 1,2 Alienware M15x Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. Alienware M15x Hard Drive Replacement: 步骤 4 中的图像 1,2 Alienware M15x Hard Drive Replacement: 步骤 4 中的图像 2,2
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
结论
7等其他人完成本指南。
Gabe
于04/09/10注册
8,013 声望
创作了3篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,541篇指南
一条评论
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 21
总计 33,056
