跳转到主内容
修复你的物品
维修的权力
商店
简介
Upgrade your hard drive for more storage space.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Unscrew the four screws indicated Pull on the tab that says "Pull" and remove the Hard Drive
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with. With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
结论
7等其他人完成本指南。
Gabe
于2010年04月09日注册
8,307 信誉积分
创作了3篇指南
团队
Master Techs Master Techs 的会员
Community
296 名成员
创作了980篇指南
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 47
总计 32,140
