简介
This guide provides instructions on how to upgrade or replace the hard drive in an Alienware M15x.
  1. Remove the battery by sliding the latch to the left and pulling the battery up.
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
    • Slide the compartment door towards the front of the computer and lift.
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
    • Remove the four small screws indicated to remove the casing to the hard drive.
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
结论
David Sann
于2018年01月22日注册
111 信誉积分
撰写一个指南
团队
Cal Poly, Team S11-G3, Banghart Winter 2018 Cal Poly, Team S11-G3, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G3
5 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 2
过去的7天: 4
过去的30天: 18
总计 150
