跳转到主内容
加入维修社区 - 创建账户
Alienware M14xR2 RAM Replacement
你所需要的
  1. Alienware M14xR2 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    询问修复机器人
    添加评论
  2. Alienware M14xR2 RAM Replacement: 步骤 2 中的图像 1,3 Alienware M14xR2 RAM Replacement: 步骤 2 中的图像 2,3 Alienware M14xR2 RAM Replacement: 步骤 2 中的图像 3,3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    询问修复机器人
    添加评论
  3. Alienware M14xR2 RAM Replacement: 步骤 3 中的图像 1,1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    询问修复机器人
    添加评论
  4. Alienware M14xR2 RAM Replacement: 步骤 4 中的图像 1,3 Alienware M14xR2 RAM Replacement: 步骤 4 中的图像 2,3 Alienware M14xR2 RAM Replacement: 步骤 4 中的图像 3,3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    询问修复机器人
    添加评论
  5. Alienware M14xR2 RAM Replacement, Optical Drive: 步骤 5 中的图像 1,3 Alienware M14xR2 RAM Replacement, Optical Drive: 步骤 5 中的图像 2,3 Alienware M14xR2 RAM Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    询问修复机器人
    添加评论
  6. Alienware M14xR2 RAM Replacement, RAM: 步骤 6 中的图像 1,3 Alienware M14xR2 RAM Replacement, RAM: 步骤 6 中的图像 2,3 Alienware M14xR2 RAM Replacement, RAM: 步骤 6 中的图像 3,3
    • Unscrew the two 6.35 mm size 1 screws.
    • Lift up and remove the panel covering the RAM sticks.
    询问修复机器人
    添加评论
  7. Alienware M14xR2 RAM Replacement: 步骤 7 中的图像 1,2 Alienware M14xR2 RAM Replacement: 步骤 7 中的图像 2,2
    • Push outward on both prongs that secure the RAM sticks in place.
    • The RAM sticks will rise upward when released from the prongs.
    询问修复机器人
    添加评论
  8. Alienware M14xR2 RAM Replacement: 步骤 8 中的图像 1,2 Alienware M14xR2 RAM Replacement: 步骤 8 中的图像 2,2
    • Grab and pull the RAM sticks up and out of their casing and set them aside.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Eugene Park
于09/30/13注册
195 声望
撰写一个指南
团队
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G4
5 名成员
创作了6篇指南
3指南评论
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - 回复 分享
I meaned r1 model
doantuan85 - 回复 分享
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 2,704
