当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the computer off.
Disconnect the charging cable from the computer.
Failure to unplug the charging cable could result in electric shock and serious injury.
Flip the computer upside down.
Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
The two screws are spring loaded and will not separate from the cover.
Slide the back cover towards you and then lift upwards to remove.
Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
Pull up on the white connector to disconnect it from the laptop.
The battery is now free to remove from the laptop and can be set aside.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
The screws are spring loaded and will not come loose from the hard drive assembly.
Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
