跳转到主内容
加入维修社区 - 创建账户
Alienware M14xR2 Hard Drive Replacement
你所需要的
  1. Alienware M14xR2 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    询问修复机器人
    添加评论
  2. Alienware M14xR2 Hard Drive Replacement: 步骤 2 中的图像 1,3 Alienware M14xR2 Hard Drive Replacement: 步骤 2 中的图像 2,3 Alienware M14xR2 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    询问修复机器人
    添加评论
  3. Alienware M14xR2 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    询问修复机器人
    添加评论
  4. Alienware M14xR2 Hard Drive Replacement: 步骤 4 中的图像 1,3 Alienware M14xR2 Hard Drive Replacement: 步骤 4 中的图像 2,3 Alienware M14xR2 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    询问修复机器人
    添加评论
  5. Alienware M14xR2 Hard Drive Replacement, Optical Drive: 步骤 5 中的图像 1,3 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 步骤 5 中的图像 2,3 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    询问修复机器人
    添加评论
  6. Alienware M14xR2 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Alienware M14xR2 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
    • The screws are spring loaded and will not come loose from the hard drive assembly.
    • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
    询问修复机器人
    添加评论
  7. Alienware M14xR2 Hard Drive Replacement: 步骤 7 中的图像 1,2 Alienware M14xR2 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
    • Set aside the now disconnected hard drive.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G4
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 50
总计 11,756
