跳转到主内容
Alienware M14x R2 Wi-Fi Card Replacement
你所需要的
  1. Alienware M14x R2 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14x R2 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Alienware M14x R2 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Alienware M14x R2 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14x R2 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14x R2 Wi-Fi Card Replacement: 步骤 4 中的图像 1,3 Alienware M14x R2 Wi-Fi Card Replacement: 步骤 4 中的图像 2,3 Alienware M14x R2 Wi-Fi Card Replacement: 步骤 4 中的图像 3,3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: 步骤 5 中的图像 1,3 Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: 步骤 5 中的图像 2,3 Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: 步骤 5 中的图像 3,3
    • Locate the wi-fi card underneath the battery and unscrew the 3.175 mm size 1 screw.
    • Lift the wi-fi card up and away from the laptop for easier access and handling of the wi-fi card.
  6. Alienware M14x R2 Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 Alienware M14x R2 Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Lift the gold connectors at the end of each wire up and away from the wi-fi card to detach both antennas, which are the black and white cables, from the wi-fi card.
    • Set aside the now free wi-fi card.
结论
4等其他人完成本指南。
angel ventura
于09/30/13注册
177 声望
撰写一个指南
团队
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G4
5 名成员
创作了6篇指南
一条评论
Fantastic.
I have replaced many things in my Alienware M14x, but am now purchasing a wireless AC/Blutooth adapter from Amazon. Your diagram allowed me to check the new card form factor with the original "Killer Network" one that shipped with my laptop in 2011.
Great pictures and great guide!
Rob MacGregor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 9,689
