跳转到主内容
Alienware M11xR2 Battery Pack Replacement
你所需要的
  1. Alienware M11xR2 Battery Pack Replacement, Removing the Base Cover: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Battery Pack Replacement, Loosen the Screws: 步骤 2 中的图像 1,1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Battery Pack Replacement, Lifting the Base Cover: 步骤 3 中的图像 1,1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Battery Pack Replacement, Replacing the Base Cover: 步骤 4 中的图像 1,1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Battery Pack Replacement, Securing the Screws: 步骤 5 中的图像 1,1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Battery Pack Replacement, Removing Screws: 步骤 6 中的图像 1,1
    • Remove the two screws that secure the battery pack to the computer base.
  7. Alienware M11xR2 Battery Pack Replacement, Disconnecting cable: 步骤 7 中的图像 1,1
    • Disconnect the battery pack cable from the connector on the system board.
  8. Alienware M11xR2 Battery Pack Replacement, Lifting Battery Pack: 步骤 8 中的图像 1,1
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Alienware M11xR2 Battery Pack Replacement, Placing New Battery Pack: 步骤 9 中的图像 1,1
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Alienware M11xR2 Battery Pack Replacement, Routing Battery Pack: 步骤 10 中的图像 1,1
    • Route the battery pack cable in the routing guide
  11. Alienware M11xR2 Battery Pack Replacement, Connnecting Battery Pack: 步骤 11 中的图像 1,1
    • Connect the battery pack cable to the connector on the system board.
终点
3等其他人完成本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 235
