跳转到主内容
加入维修社区 - 创建账户
Alienware M11x Memory Module Replacement
你所需要的
  1. Alienware M11x Memory Module Replacement, Introduction: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: 步骤 2 中的图像 1,1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: 步骤 3 中的图像 1,2 Alienware M11x Memory Module Replacement, Removing the Memory Module: 步骤 3 中的图像 2,2
    • Remove the memory module from the memory module connector.
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: 步骤 4 中的图像 1,1
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: 步骤 5 中的图像 1,1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
2等其他人完成本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了1,998篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 27
总计 560
