跳转到主内容
Alienware Aurora A5 SSD Replacement
你所需要的
  1. Alienware Aurora A5 SSD Replacement, SSD: 步骤 1 中的图像 1,2 Alienware Aurora A5 SSD Replacement, SSD: 步骤 1 中的图像 2,2
    • Power off the computer.
    • To ensure the PC is completely off, remove the cables at the back of the PC.
  2. Alienware Aurora A5 SSD Replacement: 步骤 2 中的图像 1,3 Alienware Aurora A5 SSD Replacement: 步骤 2 中的图像 2,3 Alienware Aurora A5 SSD Replacement: 步骤 2 中的图像 3,3
    • Lift the black latch at the back of the PC to pop open the side cover.
    • Carefully remove the side cover by lifting it up.
  3. Alienware Aurora A5 SSD Replacement: 步骤 3 中的图像 1,2 Alienware Aurora A5 SSD Replacement: 步骤 3 中的图像 2,2
    • Unlock both tabs on the back of the PC by pushing them up.
    • Remove the power supply latch to get access to the inside.
  4. Alienware Aurora A5 SSD Replacement: 步骤 4 中的图像 1,3 Alienware Aurora A5 SSD Replacement: 步骤 4 中的图像 2,3 Alienware Aurora A5 SSD Replacement: 步骤 4 中的图像 3,3
    • Remove the black plastic part by pushing it down and then pulling it towards you.
    • Unlock the blue latch and pull to remove the graphics card.
  5. Alienware Aurora A5 SSD Replacement: 步骤 5 中的图像 1,3 Alienware Aurora A5 SSD Replacement: 步骤 5 中的图像 2,3 Alienware Aurora A5 SSD Replacement: 步骤 5 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the 3.7 mm screw and remove the old M2 SSD.
结论
Ensure that you tightly screwed on the M2 SSD and that you inserted the graphics card back to its position so that the PC runs smoothly with no problems. Once you have completed all the steps and reconnected the cables you have successfully replaced the NVMe M2 SSD and your PC is ready to be turned on!
5等其他人完成本指南。
Sarah Mohammed
于05/10/21注册
232 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 35
过去 30 天: 167
总计 3,540
