跳转到主内容
Alienware 17 R4 Wi-Fi Card Replacement
你所需要的
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Alienware 17 R4 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: 步骤 3 中的图像 1,1
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Alienware 17 R4 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 Alienware 17 R4 Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 Alienware 17 R4 Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 Alienware 17 R4 Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
结论
另外一个人完成了本指南。
Hector Mendez III
于09/11/17注册
1,280 声望
创作了8篇指南
团队
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G4
4 名成员
创作了9篇指南
一条评论
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 45
总计 4,562
