跳转到主内容
Alienware 17 R4 Ram Replacement
你所需要的
  1. Alienware 17 R4 Ram Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Ram Replacement: 步骤 2 中的图像 1,2 Alienware 17 R4 Ram Replacement: 步骤 2 中的图像 2,2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 1,3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 2,3 Alienware 17 R4 Ram Replacement, Hard Disk Drive (HDD): 步骤 3 中的图像 3,3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Ram Replacement: 步骤 4 中的图像 1,3 Alienware 17 R4 Ram Replacement: 步骤 4 中的图像 2,3 Alienware 17 R4 Ram Replacement: 步骤 4 中的图像 3,3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Ram Replacement: 步骤 5 中的图像 1,3 Alienware 17 R4 Ram Replacement: 步骤 5 中的图像 2,3 Alienware 17 R4 Ram Replacement: 步骤 5 中的图像 3,3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Ram Replacement: 步骤 6 中的图像 1,2 Alienware 17 R4 Ram Replacement: 步骤 6 中的图像 2,2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Ram Replacement, RAM: 步骤 7 中的图像 1,3 Alienware 17 R4 Ram Replacement, RAM: 步骤 7 中的图像 2,3 Alienware 17 R4 Ram Replacement, RAM: 步骤 7 中的图像 3,3
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Ram Replacement: 步骤 8 中的图像 1,1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
结论
另外一个人完成了本指南。
Hector Mendez III
于09/11/17注册
1,280 声望
创作了8篇指南
团队
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 28
总计 2,700
