简介
This guide will teach you how to replace your RAM card allowing you to upgrade or simply replace your card.
你所需要的
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
即将完成!
结论
另外一个人完成了本指南。
