简介
This guide will show you how to replace the hard disk drive (HDD) for your Alienware 17 R4.
你所需要的
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
即将完成!
结论
2等其他人完成本指南。
