跳转到主内容
加入维修社区 - 创建账户
Alienware 17 R3 Display Replacement
你所需要的
  1. Alienware 17 R3 Display Replacement, Display: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Flip the computer upside down.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Display Replacement: 步骤 2 中的图像 1,1
    • Unscrew and remove the two 4mm Phillips screws from cover.
  3. Alienware 17 R3 Display Replacement: 步骤 3 中的图像 1,1
    • Pull up and slide cover off.
  4. Alienware 17 R3 Display Replacement: 步骤 4 中的图像 1,2 Alienware 17 R3 Display Replacement: 步骤 4 中的图像 2,2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Display Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool, pull display casing away from main body.
  6. Alienware 17 R3 Display Replacement: 步骤 6 中的图像 1,1
    • Unscrew and remove the two 2mm Phillips screws from the bottom of the display.
  7. Alienware 17 R3 Display Replacement: 步骤 7 中的图像 1,1
    • Disconnect plugs connecting the display to the main body.
  8. Alienware 17 R3 Display Replacement: 步骤 8 中的图像 1,1
    • Lift display out.
结论
7等其他人完成本指南。
团队
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017 的会员
UWT-ROSE-W17S1G1
3 名成员
创作了5篇指南
1指南评论
The best and easiest way to replace the screen!
Jhun Calvin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 42
总计 4,686
