跳转到主内容
Alienware 17 R2 Wireless Card Replacement
你所需要的
  1. Alienware 17 R2 Wireless Card Replacement, Removing the Screw: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screw that secures the wireless-card bracket and the wireless card to the system board.
  2. Alienware 17 R2 Wireless Card Replacement, Lifting the Card Bracket: 步骤 2 中的图像 1,1
    • Lift the wireless-card bracket off the wireless card.
  3. Alienware 17 R2 Wireless Card Replacement, Disconnecting Antenna Cables: 步骤 3 中的图像 1,1
    • Disconnect the antenna cables from the wireless card.
  4. Alienware 17 R2 Wireless Card Replacement, Removing the Wireless Card: 步骤 4 中的图像 1,1
    • Lift and slide the wireless card from the wireless-card slot.
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
  5. Alienware 17 R2 Wireless Card Replacement, Sliding the Wireless Card: 步骤 6 中的图像 1,1
    • Slide the wireless card at an angle into the wireless-card slot.
  6. Alienware 17 R2 Wireless Card Replacement, Connecting Cables to the Wireless Card: 步骤 7 中的图像 1,1
    • Connect the antenna cables to the wireless-card.
    • The following is the antenna-cable color color scheme for the wireless card: Main (white triangle) = White Auxiliary (black triangle) = Black
  7. Alienware 17 R2 Wireless Card Replacement, Aligining the Screw Holes: 步骤 8 中的图像 1,1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card.
  8. Alienware 17 R2 Wireless Card Replacement, Replacing the Screw: 步骤 9 中的图像 1,1
    • Replace the screw that secures the wireless-card bracket and the wireless card to the system board.
结论
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 739
