跳转到主内容
Alienware 17 R2 Memory Modules Replacement
你所需要的
  1. Alienware 17 R2 Memory Modules Replacement, Popping up Memory Module: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the base panel.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: 步骤 2 中的图像 1,2 Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: 步骤 2 中的图像 2,2
    • Slide and remove the memory module from the memory-module slot.
  3. Alienware 17 R2 Memory Modules Replacement, Aligining the Notch: 步骤 3 中的图像 1,1
    • Align the notch on the new memory module with the tab on the memory- module slot.
  4. Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: 步骤 4 中的图像 1,2 Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: 步骤 4 中的图像 2,2
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • If you do not hear the click, remove the memory module and reinstall it.
结论
Terrence15
于12/18/17注册
79,091 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 452
