跳转到主内容
Alienware 17 R2 Hard Drive Replacement
你所需要的
  1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Alienware 17 R2 Hard Drive Replacement: 步骤 2 中的图像 1,3 Alienware 17 R2 Hard Drive Replacement: 步骤 2 中的图像 2,3 Alienware 17 R2 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Alienware 17 R2 Hard Drive Replacement: 步骤 3 中的图像 1,2 Alienware 17 R2 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Locate the Hard Drive
  4. Alienware 17 R2 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the screws that connect the SSD Bay to the laptop
  5. Alienware 17 R2 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three screws holding the hard drive
  6. Alienware 17 R2 Hard Drive Replacement: 步骤 6 中的图像 1,2 Alienware 17 R2 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Alienware 17 R2 Hard Drive Replacement: 步骤 7 中的图像 1,3 Alienware 17 R2 Hard Drive Replacement: 步骤 7 中的图像 2,3 Alienware 17 R2 Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,483
