跳转到主内容
Alienware 17 R2 Screen Replacement
你所需要的
  1. Alienware 17 R2  Screen Replacement, Display: 步骤 1 中的图像 1,1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: 步骤 2 中的图像 1,2 Alienware 17 R2  Screen Replacement: 步骤 2 中的图像 2,2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: 步骤 3 中的图像 1,2 Alienware 17 R2  Screen Replacement: 步骤 3 中的图像 2,2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: 步骤 4 中的图像 1,3 Alienware 17 R2  Screen Replacement: 步骤 4 中的图像 2,3 Alienware 17 R2  Screen Replacement: 步骤 4 中的图像 3,3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: 步骤 5 中的图像 1,2 Alienware 17 R2  Screen Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: 步骤 6 中的图像 1,1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: 步骤 7 中的图像 1,1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: 步骤 8 中的图像 1,1
    • Gently, lift the display away from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 28
总计 3,135
