跳转到主内容
Alienware 15 R3 Hard Drive Replacement
你所需要的
  1. Alienware 15 R3  Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Find Power in start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the lights around are off.
    • Unplug the power supply.
  2. Alienware 15 R3  Hard Drive Replacement: 步骤 2 中的图像 1,3 Alienware 15 R3  Hard Drive Replacement: 步骤 2 中的图像 2,3 Alienware 15 R3  Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the seven M2.5x13 screws from the base cover.
    • Remove the base cover carefully.
    • Save these screws for later.
    • The screw on the top middle of base cover cannot be removed after unscrewing. But it is okay to remove the base cover.
  3. Alienware 15 R3  Hard Drive Replacement: 步骤 3 中的图像 1,3 Alienware 15 R3  Hard Drive Replacement: 步骤 3 中的图像 2,3 Alienware 15 R3  Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Remove the two M3x3 screws that are holding the bracket and one M2.5x8 screw holding the hard drive assembly .
  4. Alienware 15 R3  Hard Drive Replacement: 步骤 4 中的图像 1,2 Alienware 15 R3  Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Put bottom plate back on your laptop and secure the bottom plate with the screws removed previously.
    • Prior to reassembly, clean the dust on fans as circled in picture if needed.
  5. Alienware 15 R3  Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Your Alienware 15 R3 is ready to roll.
结论
By removing the HDD from the laptop, BSOD will never happen again when you boot the laptop. Please note that, the storage space than it was in the past.
另外一个人完成了本指南。
Yutong Yin
于05/10/21注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 1,302
