跳转到主内容
Alienware 15 R2 Wi-Fi Card Replacement
你所需要的
  1. Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,3 Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 2,3 Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 3,3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the center of the rear panel. Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Use plastic opening tool to disconnect battery cable.
  3. Alienware 15 R2 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Alienware 15 R2 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Remove the 6.0 mm Phillips #0 screw on the Wifi card. Disconnect the white and black wires, then slide the card out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 821
