跳转到主内容
Alienware 15 R2 Hard Drive Replacement
你所需要的
  1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
  2. Alienware 15 R2 Hard Drive Replacement: 步骤 2 中的图像 1,2 Alienware 15 R2 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening tool to disconnect the battery cable.
  3. Alienware 15 R2 Hard Drive Replacement: 步骤 3 中的图像 1,2 Alienware 15 R2 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Use the T9 Torx bit to remove the screws on the hard drive cover.
  4. Alienware 15 R2 Hard Drive Replacement: 步骤 4 中的图像 1,2 Alienware 15 R2 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 904
