简介
This guide will show you how to replace your Alcatel Pop 4 Plus speaker. This guide involves removing the back cover and the secondary cover where the speaker is located. Then you just pop it out and put in the new speaker.
  1. Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off. Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Remove seventeen 3mm Phillips #000 screws from the mid-frame. Remove seventeen 3mm Phillips #000 screws from the mid-frame.
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  5. Use the flat end of the spudger disconnect the battery from the motherboard. Use the flat end of the spudger tool to pry out the battery.
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  6. Use a spudger to pry the speaker from the mid-frame. Use a spudger to pry the speaker from the mid-frame.
    • Use a spudger to pry the speaker from the mid-frame.
结论
Maalik Poleon
于2018年01月25日注册
196 信誉积分
创作了2篇指南
团队
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G6
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 102
