跳转到主内容
Alcatel Pop 4 Plus Rear Camera Replacement
你所需要的
  1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: 步骤 1 中的图像 1,2 Alcatel Pop 4 Plus Rear Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 2 中的图像 1,2 Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 4 中的图像 1,2 Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,1
    • Use the flat end of the spudger tool to remove the connector.
  6. Alcatel Pop 4 Plus Rear Camera Replacement: 步骤 6 中的图像 1,1
    • Pry out the camera with the pointy end of the spudger tool.
结论
Maalik Poleon
于01/25/18注册
202 声望
创作了2篇指南
团队
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G6
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 241
