跳转到主内容
Alcatel Pop 4 Plus Power/Volume Button Rocker Replacement
你所需要的
  1. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement, Power/Volume Button Rocker Replacement: 步骤 1 中的图像 1,2 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement, Power/Volume Button Rocker Replacement: 步骤 1 中的图像 2,2
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 2 中的图像 1,2 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 2 中的图像 2,2
    • Once removed completely, use the back portion to disassemble the Power/Volume Button Rocker.
  3. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the middle insert of the elastic on the Power/Volume button rocker with tweezers.
  4. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 4 中的图像 1,3 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 4 中的图像 2,3 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 4 中的图像 3,3
    • Remove the 3 elastic bands holding the rocker in place with tweezers.
  5. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: 步骤 5 中的图像 1,1
    • Once removed, place new rocker in same elastic slots. Follow instructions backwards to reassemble.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 414
