跳转到主内容
Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement
你所需要的
视频概述
  1. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 步骤 1 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 步骤 1 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 步骤 1 中的图像 3,3
    • The Battery / Back cover is secured to the main frame by plastic clips.
    • Use a plastic tool to remove it.
  2. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 步骤 2 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 步骤 2 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 步骤 2 中的图像 3,3
    • Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
    • With tweezers careful remove the battery connector shield.
  3. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 2: 步骤 3 中的图像 1,1
    • Disconnect the battery cable.
  4. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: 步骤 4 中的图像 1,2 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: 步骤 4 中的图像 2,2
    • Disconnect:
    • Touchscreen flex cable
    • Main Camera flex cable
    • LCD flex cable
    • Vibra-motor
    • New line.Remove 7x Phillips screws.
  5. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 5 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 5 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 5 中的图像 3,3
    • Careful unstuck the Volume buttons flex cable and the Power button flex cable.
    • Use a plastic tool and remove the Logic board.
  6. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 步骤 6 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 步骤 6 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 步骤 6 中的图像 3,3
    • Use a hair dryer to warm the glass to soften the adhesive.
    • Use a knife or tool with a sharp edge and start the separating the glass from the frame.
    • Continue with a plastic tool.
  7. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 7 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 7 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 7 中的图像 3,3
    • Insert wisdom here.
  8. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 8 中的图像 1,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 8 中的图像 2,3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 步骤 8 中的图像 3,3
    • Clean the frame and install a new adhesive tape.
    • Install the touch screen.
结论
ZFix
于12/09/13注册
191,341 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,541篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 13
总计 1,738
